Marcela
Dec 02, 2018Explorer
Rear springs and overloads for '99--07 F350
My dually truck has the 5+1 spring pack with the +1 being an overload, rawr is 8250.
I have the Hellwig 3500# spring pack sitting here, to use it the tech told me I have to remove the overload spring and brackets. Removing the front bracket looks to be a pita as it is riveted, the rear bracket is bolted so no probem. Also removing the overload spring takes away from the carrying capacity of course so whatever it is rated for has to be subracted from the 3500# added by the installed springs.
I also have the Hellwig overload springs sitting here, rated at 2200# which can be added on top of the existing overload, easy peasy. Tech said these springs will of course engage the overloads sooner.
So question is who has experience with this combo adding additional spring capacity and how did it turn out. My camper is going to be in the 4500# range I imagine, with addition of trailer possible.
Maybe another brand has a better solution?
I am guessing if the 3500# spring pack is installed the reason the overload brackets have to be removed as they can engage the spring pack relieving the tension on the brackets at the ends of the springs with possible dire consequences. Though the brackets appear to be quite a ways away from the present springs and with the 3500# springs tightened down they might and might not engage the brackets.
Would like to have all the spring I can install. And don't really want to remove the present OEM spring pack as that looks to be a chore, but it is possible.
