fleetwoodmatthe's avatar
Aug 03, 2013
rear stabilers
I have 2009 280 bh Fleetwood passport and my rear stabilizer jacks are not working, i'm looking to see where the 6amp reset fuse is located at.
  • I CHECKED FROM THE TONGUE AND FOUND THE 30 AMP THAT IS HOOKED TO THE ELECTRIC TONGUE JACK, THEN I WENT TO THE BACK AND PULLED THE SWITCH OUT,NOTHING, I HAVE LIKE A CARD BOARD MATERIAL ALL UNDERNEATH THE TRAILER, I MIGHT HAVE TO START REMOVING THAT. THANKS FOR THE HELP.
  • My Forest River trailer has the circuit breaker mounted under the rig right next to the switch. My problem was that the switch is not protected from wheel spray and the switch was intermittent. I cleaned the switch using WD40 (the WD stands for water displacement) and installed a box around it to minimize future spray issues. The front one doesn't get as much spray from the tow vehicle.
