HappiJac, how I use it.
The amount of movement while the centering is happening is very slight...WHY? because you have to be very close to stop on just to get the TC between the bed posts at the rear.
Front bumpers to fit against the HappiJac front bar centering plates
IMG_0133IMG_0134IMG_0135
I added the gray top plastic to allow the TC to not hang up on bar if I had to have it higher due to uneven ground etc.
IMG_0138IMG_0140
Side skid plates on the aft tub bump-out.
IMG_0142
It rubs on the plastic (slippery stuff) skid plate attached to the bed tailgate post.
IMG_0144IMG_0145IMG_0146
Bevel front edge to make it easy to slide past...it only has to move maybe a 1/2" so there is very little issue with the aft jacks. The tolerance of the TC tub and the bed are really close...so you have to be good when backing in...And I am GOOD!! rolleyes
IMG_0147
Only mirrors and back window and the molded line on top of the DEEZEE mat help get it right...I DO HOPE I HAVEN'T STARTED A LOADING POST HIJACK!!! ack laughing
All I was doing is showing my centering devices...simple and easy to make and use!
