- DesertdreamerExplorerThere are more wires in the fix, where do i find those? They are not all marked...One of you said you fixed it from the thermostat..how did you do that?
- BizmarksMomExplorerThey need to add 2 wire nuts to the air conditioner wiring system.
My trailer is in for a fridge repair. The recall added 10 minutes to the technician's time. - Eddie_GriswoldExplorerDeleted comment
- Target13ExplorerThanks, Steve-n-Vicki. It's nice to be able to double check that it was done correctly.
- jerseyjimExplorerFriend of mine has a Passport, problem with the fridge (under warranty) but then the dealer found this exact a/c wire thing. Fixed it...but charged $ as that was not under warranty (trailer is 2 years old). Now...with the recall, he is going back for a refund.
Hope he gets it. - steve-n-vickiExplorer
this what you have
this is the recall
the red wire /white stripe and little thermostats wire are removed from the purple wire and red wire connection , and are hooked together - GaryWTExplorerMy dealer told me it would take 10 minutes. Trying to get some other things done as well at the same time.
- Target13ExplorerI asked Keystone to give me details of the fix. They refused.
- steve-n-vickiExplorerI fixed mine today, very easy fix took 2 wire nuts
- N2AntiqueOakExplorerThe place we bought our Premier from sent a tech out 4 days after we called. Took him 15 minutes and he was gone.. No parts, just rewired at the thermostat.
44,068 PostsLatest Activity: Jun 27, 2026
