ScottG's avatar
ScottG
Nomad
Jun 17, 2018
Recharging vehicle AC Q
After 16 years, last year My AC started showing the classic signs of low charge (and for some reason it didn't get better over the winter...) so today I hooked up the gauges and charged it from a bulk R134 tank.
I got both the high and low pressures in spec but the high was just barely. It didn't seem like adding more R134 was going to do anything but raise the low pressure side but I could be wrong.
Question of those knowledgeable with these things; Was I not able to get the high side higher because the system needs to be put under a vacuum or rather, evacuated and recharged?
Everything is working fine and in-spec but I wonder if it could be better.
Thanks in advance,
Scott
  • One of two things either the high pressure limit switch isclogged orthe dryer needs replaced are the common causes i know of. Vacuming down would help removeany moisture orcontaminates
    On a bulk tank did u flip the tank upside down to fill as suppose to do
