River4ever's avatar
River4ever
Recommend TC??
Current Truck
2013 Chevy Silverado
Diesel 4x4 LTZ 71
4 door crew cab
8 foot bed
SRW
GVWR 10,000lbs
7750lbs @ the scales full of fuel
270/70/18 BFG All-Terrian E Rated 3740lbs
Torklift tie downs
Firestone air bags
Torklift lower stable loads
Just my wife and I & 1 dog+ 19foot Jet boat occasionaly
Just trying to see what the experts think?
Thanks in advance!!
Mike
  • What's important to you floorplan wise? What's your budget? Do you want a slide? Do you boondock or stay in campgrounds because that will make things like tank size or solar/generator options more or less important.
    Adventurer makes several nice mid size campers, Wolf Creek has the 840 and 850. Lance has several mid size units. Arctic Fox has the limited run 865 available right now (don't look for it on their website).
  • put 19'5 wheels and commercial tires rated at 4850# each then keep the rear axle scale weight under 8000 loaded and you should be good to go towing the boat too with most single slide TC's
    Beefy anti-sway bars too are a must
