donn0128 wrote:
Heater is a heater is a heater. All electric heaters are limited to 1500Watts. That keeps them undrr the 20A most household breakers will be. What else are you attempting to use in the same circuit? Realisticslly an electric heater must be on a circuit that nothing else is on it. Also plan on replqcing the breaker. Once they start tripping it will only get weaker.
Again, only in your world.
I have a couple electric heaters that pull significantly more than 1500W. But yes most Walmart plug in heaters are designed to work on normal household circuits.
Agree though, contrary to Dutchman, new breakers are stronger and get weaker with each flip. Same with GFCIs. They do wear out.
