We discovered that our TT only comes with a 30amp service.
The second AC will most likely be used at night when we sleep if needed.
I do have a related question. If I have 30 amp TT with a 15k AC, can I run a 15K AC in low and a 13.5K AC at the same time? I am assuming both at high together won't work.
One solution I heard was to run a plug to the storage bay from the second AC and use a 20 amp circuit at the campsite. This is a last resort but probably doable with patience.
Please note that we camp in AZ a lot. I tried to avoid hot days but when you go boating and want to camp, the heat here in unavoidable.
MC
