jaycocamprs
Feb 22, 2020Explorer
agesilaus wrote:
I'm getting rid of our 15 inch Marathons on our TT and moving to 16in probably LT225/75R16 with new rims. I have people recommend 16 inch Michelin Defenders but those are well over $200 each. I see someone used GR Commercial T/A with good results but someone else suggested asking for ideas. Please don't restart the LT vs ST fight.
We did this upgrade on a Jayco 285RLS in 2009. Bought 5 Commercial T/As in 235/85/R16. In 2011 we traded for the Mountaineer, had the tires removed and remounted on it. The spare failed at this time, had never been on the ground. Dealer made it up. In 2013 one of the remaining original tires started to fail. At that time I went with the Bridgestone R250, they ran without issue until last year. When we replaced the BFG's we found the the 1st replacement tire was subject to recall and it was replaced again, and we are using it for a spare, it has never been on the ground. We are now running G637 235/85/R16 Sailuns. Also had 1 215/85/R16 BFG fail do to tread separation on the 05 truck, replaced all 6 with the Bridgestone R500, they were on the truck when it was replaced with the 2018.
Michelin XPS Ribs or Bridgestone R238 all steel tires would be best, but not cheap. Commercial T/As, Bridgestone R500, Sailun Terramax HLT, or other non steel tire should give you years of good service.
