- Caveman_CharlieExplorer II
Blackdog79 wrote:
Caveman Charlie wrote:
Blackdog79 wrote:
I will mirror what others have said, it probably won't be worth the time and expense of getting rid of all the non aluminum materials. I just converted a 27 foot into a car hauler and what I got out of the scrap metals was only enough to buy what was needed for conversion. I burned all the wood and have a dumpster at my shop to get rid of everything else, otherwise it would have been a negative endeavor. Best bet is see if a scrap yard may give you a price for the unit, I know some around here will do so. Usually a few dollars per hundred pounds, but less hassle.
Into a car hauler? Are the axels heavy duty enough for that??
The trailer had a 6K GVWR, I also cut the frame shorter. I do want to get it on a scale to see how heavy it is empty. FWIW though the car that is regularly carried is a lightweight drag car, so not concerned until I start carrying bigger stuff around.
OK, Thanks - Blackdog79Explorer
The trailer had a 6K GVWR, I also cut the frame shorter. I do want to get it on a scale to see how heavy it is empty. FWIW though the car that is regularly carried is a lightweight drag car, so not concerned until I start carrying bigger stuff around. - SprinklerManExplorerDual 5 lug axles are generally good for 7K gross .
Into a car hauler? Are the axels heavy duty enough for that?? - mlts22Explorer IIDuring SXSW, there were people who shaved the VINs from a stripped trailer via an angle grinder, pulled the plates, and left the hulk for the city to deal with. Of course, tampering with VIN stamps is a class "A" misdemeanor under Texas law, but in all the hubbub (and the attempted killing spreee), those tend to be a lower priority for APD.
If you have a Freecycle or Craigslist, that might be an idea as well. - Blackdog79ExplorerI will mirror what others have said, it probably won't be worth the time and expense of getting rid of all the non aluminum materials. I just converted a 27 foot into a car hauler and what I got out of the scrap metals was only enough to buy what was needed for conversion. I burned all the wood and have a dumpster at my shop to get rid of everything else, otherwise it would have been a negative endeavor. Best bet is see if a scrap yard may give you a price for the unit, I know some around here will do so. Usually a few dollars per hundred pounds, but less hassle.
- johnm1ExplorerAnother thought ... I was at a auto auction yard a while back and they had a TT that had had a fire and one of our local fire dept's was going to use to practice with ("junk" TT's don't come around very often) ... see if you could donate it to your local fire dept and take the tax deduction value.
- westendExplorerI'm guessing a late model rig would have about 150-200 lbs. of siding and trim. If it was me, I'd strip everything of value if the insurance company doesn't care. As was posted, the appliances have the most value.
- colliehaulerExplorer III
mobilefleet wrote:
That late of a TT the frig, stove, water heater, furnace A/C will still have value on Craigslist if in good shape. If the whole TT is trashed put it on Craigslist for best offer, someone will buy it.
I have a wrecked 30 ft Zinger trailer, 2006 model. Local scrap yard says 41 cents/lb for scrap aluminum. Is it worth it to peel all the siding off? Have no idea how much weight the siding makes up - Caveman_CharlieExplorer II
jimw606 wrote:
Set it on the street, someone will strip it for you.
Not around here. Not everybody has crime you know. In fact if you set it on the street the city is going to give you a big fine .
44,068 PostsLatest Activity: Jun 01, 2026
