BobsYourUncle
Apr 26, 2014Nomad
On my rebuild project from a number of years ago, I stripped all the siding off and replaced it.
After too many withdrawals from the memory banks, I don't recall the exact figure, but it seems to me I had in the neighborhood of 150 pounds of scrap. If the roof is aluminum, consider that too. A roof skin of that size will be about 125 pounds or so.
At 40 cents you can do the math and see if it is worthwhile.
Another consideration - is it aluminum stud framed?
Removing the siding is fast and easy. Start from the bottom, rip it of the staples and unhook the lowest piece out of the one above it. This will expose the staples holding the next piece to the studs. This is where it gets really easy. Quick pry with a bar or hammer from the framing to the siding and it will pop right off.
Of course, there are windows and vents to either remove or cut around.
Might be easier to cut the top piece laterally when you get there, as the drip rail is screwed on over top of the siding.
44,068 PostsLatest Activity: Jun 09, 2026
