Kampfirekid
Jul 11, 2013Explorer
mosseater wrote:Kampfirekid wrote:
I confirmed with Reese that the 1200 and 1500 Trunnions bars are the exact same length and snap brackets are heavy duty on the 1200 and up (same).
I decided to not get a replacement head now, or try to configure the setup with the 1200 bars. I ordered the Equalizer 1400. After setting up the Equalizer, I will find a replacement head for the Reese and sell the whole Reese Dual Cam setup. I'm not interested in disconnecting bars when backing up or turning tighter turns. In close to 8 years with my last Equalizer, I never had a hiccup. The potential of breaking another head doesn't interest me.
Thanks to everyone for your input.
I won't comment on your decision to go with the Equalizer. I never owned one and have heard they work well. My only point is the continuing notion that Dual Cams have to have their bars removed to back up. Unless it's an extreme compound angle and/or the hitch isn't set up correctly, there is no need to remove the bars to back up. This myth continues to perpetuate and it simply isn't true outside the parameters I mentioned. I had an issue early on similar to yours (wrong head and bad set up) and did in fact blame the hitch initially when I spit a bar across a campground parking lot late one night while turning around. At the time, my hitch was not set up correctly and I did not understand all that I now do. Since my issue has been resolved, I have been backing into spaces for almost 4 years without a hiccup and never removed the bars once. Just an FYI. Good luck with the new hitch.
I appreciate your thoughts. I should have clarified I dont want to have to remove bars with the Reese when bacing in to my driveway. I have a really tight turn, and would need to remove the bars to avoid possibly cracking a head. While i know this head did not fail from my work as it was a bad casting, I am not interested in dealing with what seems to be a real possibility. I called close to eight dealers looking for parts of which I found none available. Several told me it was likely the head failed from improper setup and/or backing up without removing the bars.
I dont believe standard backing up is a real issue, but the inability to get replacement parts locally with the likelyhood of this reocurring mahes me shy. In eight years and three different trailers of different weights, the same Equalizer hitch never gave me a hiccup. I dont even know of a potential issue exists with the Equalizer. With my experience, its about foolproof, and extremely easy to set up. Twice I have had to depend on the Equalizer in an emergency, and it makes me feel much more comfortable.
Just because I am an engineer tupe, I'd love to spend the $400 to get the Dual Cam head replaced and the heavier trunnion bars. Unfortunately, seeing i could get the Equalizer for $535, i couldnt see spending the money on the Dual Cam only to not get it out of it if not satisfied. I still am thinki ng of replacing the head and selling the Dual Cam, but I cant see making anything on the Dual Cam on Craigslist after shelling out for the head.
44,066 PostsLatest Activity: Apr 10, 2026
