Dewclaw's avatar
Dewclaw
Explorer II
Aug 21, 2017
Reflectix over the skylight
We are home from a trip to the midwest. On this trip I used a piece of Reflectix over the top of the skylight, secured with small binder clips to the skylight hatch edge, when were were camped longer than overnight. It was easy to attach and remove by opening the hatch and standing on the bed. I wish that I'd thought of it years ago. It made a terrific difference in keeping the bunk cool.
  • I have been looking for a solution for covering the skylight too, but was hesitant because I was afraid it might deteriorate the plastic in the skylight.
  • I just have a piece of 3/4" foam board that fits snug in the opening. Put a piece of tape on the top side letting it hang a little down one of the edges so it's easy to grab and pull the foam out. Easy to pop it in and out as required from inside the camper without having to open anything.
  • I used a/c duct works insulation. It's sticky on one side and aluminum on the other. It's been on there for years.
  • It makes a difference putting it outside as long as it stays there,we did it both ways but when we ordered the new camper they put a fantastic fan up there instead much better fix.
  • I put some reflectix inside the skylight, didnt think of putting it outside. Does it make substantial difference? You would think someone would make a cushion to fit that like they do the standard vents.
