dessa1930 wrote:
its a dometic rm2652
YES.......
Your model has a factory pre-set thermostat control (no temp setting adjustments on upper panel)
The thermostat uses that thermistor as temp control sensor in food compartment.
The tip of thermistor should just protrude from top of clip and clip should go on far right fin.
Moving it up/down on that fin can affect overall temp in food section by 4-6*F
Up.......colder
Down.....warmer (less cool)
Surprised there isn't a 'sticker' on food section wall indicating 'adjustment' (or maybe there is)
