BarneyS
Oct 13, 2014Nomad
I would put some towels in the bottom of the fridge just in case some of the defrost water ends of down there. Check that the drain tray under the iced up fins is pushed all the way back to the back wall of the fridge. This tray collects the water as the ice melts and routes it to the drain tube/hose
That hole at the back left edge of the tray is connected to the drain tube/hose that leads outside the back of the unit. Make sure that tube is not plugged by a wasp nest or something so the melting ice water can drain properly.
You will also probably have to mop up water from inside the freezer. Any ice on the back or bottom of that will often just melt and stay there so you need to get it with a towel.
Also, prop open the door for the winter when you are done.
Barney
Barney
44,056 PostsLatest Activity: Jan 19, 2026
