LoudRam's avatar
LoudRam
Refrigerator not working Norcold N611
Second time out in a new camper. It worked great the first time. I had it on for 15 hours yesterday when my wife called me at work and said that it wasn't cold yet. I had her switch it to gas and it didn't help. Freezer was warm. I had to wait until this morning when I got home from work to check it out. Been on now almost 6 hours this time and again the freezer is still warm. The fridge reads 67°. Neither electric or LP gets it cold. The ammonia tank and lines are very warm almost hot and I can hear it circulate. We have flame and the electric works too. The led is green. No trouble codes. The thermistor reads 10.6 k and according to the Norcold chart that's dead on. I'm watching the temps using my Fluke with a thermocouple wire. What can I check next? We're camping this weekend and I may end up having to use coolers.
  • JCR-1 wrote:
    These absorption refrigerators are junk. Too many controls and ******** to contend with and in hot weather they barely cool . Have to use fans and other gimmicks.. Junk I say !
    And your solution is?
  • These absorption refrigerators are junk. Too many controls and ******** to contend with and in hot weather they barely cool . Have to use fans and other gimmicks.. Junk I say !
  • Ron3rd wrote:
    This should not be happening. You said new trailer, it must still be under warranty
    It is. If it was a quick easy fix, I'd do it. But since it isn't, I'll be calling for an appointment on Monday.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
  • Lynnmor wrote:
    You checked the flue where the burner exhausts, but did you check the entire ventilation area up thru the roof vent?
    Yes, I went on the roof and took the rain cover off and looked down.
  • You checked the flue where the burner exhausts, but did you check the entire ventilation area up thru the roof vent?
  • Just talked to one of the RV techs where I bought it and he said to check to see if anything is blocking the chimney. So that's my next step.
    Edit: No blockage. Back to square one. Looks like it may go in for some warranty work.
  • Ava wrote:
    Unless you are way off level, it sounds like the cooling unit is plugged and there is not much of a fix for that.
    I'm level.
  • Unless you are way off level, it sounds like the cooling unit is plugged and there is not much of a fix for that.
