MitchF150
Jul 22, 2015Nomad
Some folks say that running with the propane on while just driving down the road is a bomb waiting to happen.
Other's will fill up with fuel with it running and use some common sense.
If it makes you feel better, just switch off the fridge (leave the tanks on) before you pull up to the pump.. Nothing wrong with that. You just have to stop before pulling in. Get out. Go into the trailer. Turn off fridge. Get back into truck. Pull to pump. Fill up with fuel. Pull forward. Get out. Go into the trailer. Turn on the fridge. Get back into truck. Continue on your trip.. :)
Or, just pull up to the first pump, leaving your trailer outside of the pump line all together. Fill up with fuel. Drive away... :)
Or, just leave your fridge off while you are traveling if that works for you too..
There is only what works for you and that's what you should do..
Mitch
Mitch
