Dakota98
May 07, 2015Explorer
I don't know if this would be of any use to you but,
A few years ago I secured the bottom edge of a Pop-Up I had with this trim. It's actually used as corner edge protection in a S&B to protect the edges of an interior entry way. It's clear plastic & can be painted, if needed. I measured & cut the lengths needed to go around the bottom of the PU & pre-drilled the screw holes, so as to not split the plastic when mounted.
Just a thought.
HOME DEPOT
Just a thought.
HOME DEPOT
