Powerdude
May 26, 2018Explorer
2edgesword wrote:IdaD wrote:
The "gas has more payload" line is a complete load of bunk. While technically true on the door tag it means absolutely nothing in terms of real world weight carrying capacity.
OP I'd recommend spending some time reading upon the CP4 fuel pump in that engine. If you're comfortable with that go for it - it's otherwise been a very reliable engine as far as I know, and it certainly performs great.
I'm not sure what you mean by "true on the door tag it means absolutely nothing in terms of real world weight carrying capacity". I looked at the specifications for an F-250. The gas and diesel have the same GVWR (10,000 lbs.) but there is a 600+ lbs difference in cargo carrying capacity. As an example the cargo limit for a 4x4 regular cab 6.2L gas is 3,285 lbs. versus 2,663 lbs for same configuration 6.7L diesel.
Can you explain further what you mean by it makes no difference in the real world?
Well, when I bought my truck, the gas truck had 600 lbs more payload capacity, so I don't really think that's bunk at all.
It fact, it allows you to carry more bunks...haha !
Your call on the gas and diesel. It's a personal preference really. 8700 lbs is no sweat for a 6.2L F250.
Mine has towed that much (a beefy skid steer a few times), and carries a heavy loaded truck camper with a family of 6.
Personally, given that the diesel is the same price basically as super unleaded, and I don't tow really heavy, the gas truck is a no-brainer, and I saved the price of a diesel option.
Get a brand new gas truck instead of a used diesel. You'll save money in the long run, because you're not buying anybody else's maintenance practices. Just my opinion. My truck has had an oil analysis at every oil changes since new, I know what goes in it and how it drives, and what it can do.
44,066 PostsLatest Activity: Jul 25, 2018
