Usmc68 wrote:
Hi all,
I know this is a loaded question but what is a good brand of travel trailer? We are getting rid of our 1994 Callista Cove 27' Class C and going with something we can pull with my 2000 F250 7.3. Also that can sleep at least 6 adults (3 teenagers) and have some pop-outs My neighbor had a pull behind (Springdale summerland series) and has had nothing but problems. We were looking at Grand Design. We also want to stay below 30K if possible. Thanks in advance,
Semper Fi
You might need to put the brakes on this until you figure out just how much payload you have..
7.3 Diesel plus assuming 4x4 and if you have super or crew cab long bed you will be pretty low on available cargo on that truck. It is heavy to start with, north of 8K lbs and F250s are normally maxed out at 9,999K GVWR (IE 10K GVWR)..
Had a co-worker that had a F250 reg cab long bed 4x4 XLT, always complained that the PA turnpike scales would nail him on the next higher weight bracket if he spiked the brakes at the toll booths when stopping.. His was right at 8,100 empty, next weight class started at 8,200 lbs..
Yes, it is a 7.3 and yes it can pull stumps, but at a cost of less payload weight.
As far as "reliable" in trailers, not much there to go wrong as you have wheels/axles/brakes and for inside you have appliances like furnace, A/C, water heater, fridge, water lines, electrical and then silly things like drawers and such..
Much of the items are commonly used across all RVs such as appliances, furnace, water heater, A/C, there is no "seconds" or lower quality to these common appliances.. Expensive RVs use the exact same appliances as the cheap RVs..
Where most complaints really stem from is lack of quality of the workmanship when the unit was assembled.. That can be poorly installed water lines or electrical connections or poorly built cabinets, drawers, doors..
Figure out how much available cargo you have on your truck, then find a trailer that stays within your cargo of the truck and suits your needs.
