climb.on wrote:
I am moving my pair of Costco Golf Cart Batteries from the tongue, to the rear of the camper under the bunk area. Primary reason is to get my tongue weight down a little bit. I've done all the calculations and scales visits and this is a good solution to keep me in the 900-1100 or 12%-14% tongue weight range.
So I would obviously need to put the batteries in a sealed, secured and vented battery box top and bottom - no problem. The new battery location would be located right next to the charger/converter, so wiring would be very convenient. This pic shows the new location.
Question: Is rewiring the batteries in a new location, as simple as I think it is? Battery negative bonded to the frame and Battery Positive to the 2nd lug of on the charger/converter circuit board (see picture)? I would also add a battery disconnect near the new battery location, like we have up front.
Also, there are electrical component wiring (emergency brake, tongue jack,etc) at the old location on the tongue that I think will still operate as long as I leave the existing positive battery cable in tact. I will leave all the existing wiring to the front, in tact anyway, as to easily return to the original setup if desired and to keep power to the front junction box. Is there something I am forgetting to consider here?
I like your idea of moving batteries, but your plan will not work.You are loading a 150lbs on the heavy side of your trailer.
MM49
