MitchF150's avatar
Jul 06, 2015
Remember the good ol' days...
Ah, remember when this truck was what we all thought was all you needed to tow a #6000 TT with AND have a slide in canopy in the bed with the 2 kids and dog back there! ;)
This is my Dad's 1971 F250 with the 390/C6 that he just recently restored.. He bought it brand new in late 1970 when I was 7 years old. I so remember the day we picked it up! I wanted him to get one of the brand new 1971 Mustang Mach 1's they had (with the 429 in it.. :) )
But, this is what we used to go camping with.. We started with 8' slide in cab over campers and eventually got the TT and the little slide in canopy that my sister and I rode in for thousands of miles with the dog of course too.. :)
Anyway, no AC, no power steering, no nothing! But we did just fine in it and I'm sure it was overloaded anytime we went out, but it made it every time!
Anyway, just had to post because I learned to drive in the truck and it drives and handles the same way it did back in the day and It just brings back a lot of good memories... I'll get this truck someday, but not too soon I hope! ;)
Just proud of Dad for keeping it all these years and bringing it back to life again.
Mitch
  • Excellent post. I wish I still had my 79 F-250.
    Thanks for sharing.
  • Good looking restore!! Had a '72 GMC w/ in cab gas tank as well. 350 cu in, 4 speed, manual steering. Had it for 5 years or so till it mated w/a tree.
  • Ha, I think it's only #7700 GVWR! It's a "Camper Special" with the "Custom" trim.. (2wd)
    I think it has 4.10 rear gears... All I know is it revs like a SOB going 65 mph and gets 9 mpg towing or not.
    Yes, when I heard the sloshing of the gas in the tank right behind the seat, that brought back a lot of memories... If you took a hard right turn with a full tank of gas, you'd get gas fumes in the cab!!
    The brake controller he had back then was one that slipped over the brake pedal itself! Remember those! It was like a sewing machine pedal.. The more you pressed down on it, the more power to the trailer brakes.. If you didn't need much trailer braking, you had to angle your foot and put more pressure on top of the pedal and press down so the trucks brakes engaged...
    I remember going up the Grape Vine pass being in the camper in the bed, towing that old 1976 Taurus TT with Mom and Dad up front with that truck in 1st gear going maybe 25 mph and Dad's foot to the floor.. Oh yeah, he had to turn the heater on full because it was also running hot.. :) This was when it was already 90* outside!
    Ah... The good ol' days! :)
    Mitch
  • In the cab 18 gallon fuel tank! That brings back memories!
    I had a rare 1975 F-350 supercab! Trailer life did a test report on a white one, and I test drove that truck before buying mine in 1987. I got mine in red and white. Had a 460" V8 and C6 transmission. I had a 3.73:1 rear axle, something that was a excellent ratio, considering it did not have overdrive. Plenty of power, and still low enough RPM at 65 to get 10 MPG.
    I also had a camper on the truck most of the years that I had it. It was also able to tow about 10,000 pounds. Without being over it's 9,600 pound GVWR. I had 9.5R16.5 tires on the back rated at 3,450 pounds. Front tires where a little smaller, and lighter duty.
    The 'better' camper truck was the F-350 Super Camper Special, with the 7" longer wheelbase, spare tire under a cover on the passenger side, just behind the passenger door. It also featured a 40 gallon aft of rear axle fuel tank.
    In 1974 Ford dropped the in the cab fuel tanks. Something about if the truck got on it's side (in a accident) the gas cap would fall off or rotate loose, and all the gas would spill out, then catch fire. GM had the same problems, and after 1975 all gas caps needed to be in recessed area, with a door over it.
    I had great power steering! Extremely light, I could palm the steering wheel, and make three turns in a couple of seconds! That brings back some fun memories!
    So is your dad's F-250 above or below 8,600 GVWR?
    Have fun camping!
    Fred.
