opnspaces
Nov 25, 2015Navigator III
I've done it once on my Jayco. Now that I've done it once this is how I would try it if I had to do it again. I think I posted this once but it was years ago. If I find it I'll post again. But in essence;
Drain the tank. Use your leveling blocks to tilt the trailer to make sure the tank is empty.
Remove the toilet (unscrew the water line and the two bolts and lift.)
Pull the screws out holding the toilet flange to the floor.
Try to lift the toilet flange up. You might have to use hammer and punch to unscrew the flange off the top of the tank, I did.
Go up on the trailer roof and remove the screws and remove the vent cap. Make sure the vent line is free to slide down out of the roof as the tank lowers.
Under the trailer:
Pull any underbelly covering to expose the tank.
Take a digital picture of the level sensor wiring colors, then remove the wires but put the nuts back on the posts so you don't lose them.
Disconnect the drain piping and move it out of the way.
Get a small floor jack (the kind on wheels not a bottle jack) and a piece of wood (maybe 18 inches square)
Use the jack to hold up the tank with the piece of wood between the tank bottom and the jack (it's bulky, but not really that heavy)
Remove any screws that hold the tank up.
Slowly lower the tank a few inches and check that the vent pipe is coming down. If the pipe is coming down lower it a bit further and check again.
As soon as you can, slide your hand on top of the tank. Reach up and see if the vent pipe will pull out of the top of the tank. Mine was glued, but some are just slipped into a rubber grommet.
If the vent is glued in you can slowly lower the tank and then hacksaw through the vent pipe. Make sure you leave enough room to glue the pipe back together when reinstalling. On mine I just replaced the entire pipe as it was just a piece of 1 1/2 black ABS drain pipe. If you go this route you'll have the feed the new pipe in from the roof and down to the tank.
That's it in a nutshell. So what's wrong with your tank that you need to remove it?
Under the trailer:
44,068 PostsLatest Activity: Jun 17, 2026
