- Ron3rdExplorer IIIWe had the Extend A Shower in our previous trailer, one of the best mods I ever did. Loved it, and as a bonus, you can hang damp towels over it. We replaced curtain that rolled with wheels on a track attached to the ceiling. I filled the holes that were left when i removed the track with some white bathroom caulk and you would have to look very close to find them. As to the mounting hardware, I don't recall exactly but used the supplied hardware. I did not seal the screws as it really did not get wet up there, but it won't hurt to do so.
- BumpyroadExplorer
al7601 wrote:
I read that some folks used molly bolts which will make a nice secure fit.
the molly bolts I am familiar with take a huge hole to get the fitting thru. wouldn't want to tear up my wall that badly.
bumpy - 98coachmanExplorerUse the plastic corkscrew anchors that are designed for sheetrock. They really work well in the light paneling. :C
Good luck,
Bill - pasusanExplorerI just moved the shower curtain track itself out about 6 inches - works great. I did put dabs of caulking in the old screw holes - just for looks.
- al7601ExplorerI read that some folks used molly bolts which will make a nice secure fit.
- Need-A-VacationExplorerI have an extend a shower curtain rod Inness to install as well. My tentative plan is to leave the factory track in the ceiling with the stock curtain and see how it works out. If it doesn't, than I will remove it or reinstall it a little further out.
Hornnumb2 wrote:
I like to use the rivets that split on the back, never had a problem with them.
Do you have any pics or a link to the style "rivets" you have used by chance?
TY! - naturistNomad III left the track and hangers be and just installed the new rod. There is no need to seal the holes because water doesn't get up that high. Well, not if you are taking a regular shower. If you and the missus get in there together and really whoop it up, all bets are off. But if it really troubles you, you might put a tiny dab of white caulk under the screw head before you drive it home. But I really don't think you need it.
- Hornnumb2ExplorerI like to use the rivets that split on the back, never had a problem with them.
- budwichExplorerthe odds of any amount of water going up to get at where the curtain rod anchors is slim to none. I wouldn't worry much about it. More worried of potential anchor screw pullout if you don't hit some support.
- al7601Explorer
Bumpyroad wrote:
can you just leave the track and curtain as it is and mount the extended shower rod below it a bit to push the curtain out? if it doesn't work properly after testing it out for a while, then you can worry about removing the old track or just leave it there.
bumpy
I guess I could do that. Probably look better too.
Do you think regular bathroom silicone caulk around the new screws I drill will prevent water from intruding?
44,070 PostsLatest Activity: Aug 05, 2026
