JIMNLIN
Aug 07, 2016Explorer III
Like any mobile home any 33' TT can be jacked and blocked without bending the frame. Nor do they require the trailer to be bolted to a concrete foundation to be solid.
We lived in our 32' 5er for 7 months one winter. I cut up 3' rr ties for cribbing. The unit was rock solid.
My tires had 2"x 8" under them so they didn't get wet or contact the ground. I also skirted the unit to keep out the cold. For 7 months I keep the tires at max pressures.
Don't jack against the frame from a single point when raising a heavy trailer.
Block both ends and a couple (even more if you like) of points evenly spaced between the ends.
Be aware those blocks can settle after hard rains so they may need re-adjustment.
Your local mobile home servicing dealer can give you pointers if your setting up for several years.
