Gdetrailer
Aug 07, 2016Explorer III
westernrvparkowner wrote:
Whatever you do, don't use cinder blocks. They are not designed to support that much weight. When one cracks, which it will, there will be additional stress on the rest of them, and you will have a serious malfunction. Use solid concrete blocks, or solid wood, like railroad ties.
Personally, I wouldn't give up the ability to move the rig, and move it quickly. But if it is allowed where you intend to place it, it is your choice.
Umm.. perhaps you NEED to tell ALL of the millions of MOBILE HOME OWNERS this..
First of all, the blocks you get now days are CEMENT BLOCKS, NOT "CINDER" blocks.
Second of all, CEMENT BLOCKS are the main way mobile homes are set (I KNOW THIS VERY WELL since I OWNED a mobile home at one time). Not to mention know quite a few owners of mobile homes over the years and have never seen a broken block or a mobile home that fell off the blocks.
To use cement blocks correctly you MUST set them with the cell openings top and bottom.
Under no circumstances should you lay the blocks on the sides or stand them up (ends up and down).
Cement blocks have the greatest strength ONLY with the cell openings up and down.
Then you make pilasters by placing two blocks side by side, next layer turn the blocks so that layer is now running across from the first..
You can put a wide block of wood over top the last set of blocks, this will cushion the blocks from any quick drop and spread the weight across the block
Doing so makes a safe, stable stack.
