westend
Apr 09, 2016Explorer
Yes, there may be glue-up fittings from the tanks to drains, tank to vents. My black tank had a glue-up fitting to the tank but a threaded fitting to the closet flange. The vent was glue up all the way to the roof. The Sawzall makes any problem with removal, moot. At the worst, you may have to replace the closet flange and add in some drains from the main drain to vents. Since this is all ABS, it is an easy task.
Good luck with your plumbing!
