Ty151's avatar
Ty151
Removing Lance 815 windows
I have a 2005 Lance Lite 815. I’m in the process of tinting the camper windows and can’t figure out how to tint the slider part of the windows.
I need to remove the screen or remove the actual slider windows to apply the tint. Anyone have experience with this? Thanks
  • I haven't seen all windows so can't say for sure, but it is an easy check. If you look closely, you will notice the plastic pieces protrude a bit beyond the window frame which is to keep the window in place.
  • This worked on my pass through window. With the window closed, remove the bottom plastic piece where the window slides. Start at the end away from the slider. Once you get to the slider end, you should be albe to slide it out from under the window. You a screwdriver or heavy duty dental pick to get it started. Then repeat for the upper plastic piece. Once both are removed, you can then open the window and slide the slider all the way to the left. Finally pick it up, tilt out the bottom and then remove.
    While you have it out, suggest you remove the bottom plastic piece from where the window sits when closed and clean the debris from under the track as this tends to build up and eventually clog the drain holes.
    And make sure you make careful note of position, direction, and location of each plastic piece so you can reinstall properly of the drains may not work as intended.
