delwhjr
May 11, 2017Explorer
NMDriver wrote:
Rule of thumb "if you burn your thumb by touching the hub, check the bearings"
Seriously, if they are not getting to hot to touch then they are fine. Get into the habit of checking them for overheating at each stop. Use the back of your hand and if you can feel the heat radiating off of the hub, before you touch the metal then it is to hot.
Get an infrared thermometer. Quick to check temp on anything, just point, click and read the display. No need for potential burn ward visit.
