- Roman_DuckExplorerDepends on use, nonuse. average would be no more than 2 years or the manufactures specs. When you clean them for pitting inspection do not use gasoline, use kero instead.if you need to replace them, make sure to change the races also. Most inportant is to do regular inspection on the wheel assemblies, including the back side of hub; check the grease seals, make sure they're not leaking.
- 1492ModeratorMoved from Forum Technical Support
- powderman426ExplorerEvery two years has always worked for me. I think more important is to chck hub temps after a long haul using a IR temp gun.
