jjjandrbaker's avatar
jjjandrbaker
repacking wheel bearings
I need to get my bearings repacked. I don't want to go to the dealer. Last time, they kept my little trailer for two weeks because the big rigs are their priority customers. I can't seem to find a place to have it done. Does anyone have any recommendations for places in San Antonio?
By the way: Nobody needs to bother to tell me how easy and inexpensive it is to do it myself. I don't want to do it myself. I just don't!
Thanks.
  • Your local chain tire dealer like Goodyear, Firestone, Les Schwab and others all do this kind of work. Trailer repair shops also do this.
    But if you are so inclined this is an easy thing to do yourself and Get Right.
    Just google it and see.
  • X2 ,other wise they,ll just use the easy lube zert fitting and be done in 15teen min. and charge you for doing the job right.
  • rbpru wrote:
    I suspect if you take them to a shop, they will just use the EZ lube option rather than hand pack them
    I had mine done at the local tire shop.
    You can always ask for them to keep the old seals so you can match them up when you buy new ones. If they have to pull a hub, there is a likelihood that your bearings will be greased correctly (with a packing device).
  • I suspect if you take them to a shop, they will just use the EZ lube option rather than hand pack them
  • Look for a truck service place and ask if they can do it or know some place that can.
  • I had my tire shop do mine. I could look at their work and my bearings. It feels like the hubs run cooler after hand packing.
  • Could try a tire shop as most do small mechanical jobs too.
  • Can't say for San Antonio, but most any place that sells/services trailers could do it. Any small shop, with a qualified mechanic, could handle it. Just don't get the kid down the street with no experience. Ask a friend, if they know of a trusted back alley mechanic in the area. Maybe a mobile RV service guy in your area.
    The RV dealer may not be the best choice anyway.
    Jerry
