lincolnmatthews
Jan 27, 2014Explorer
Was just looking at it quickly over the weekend, I think the hot water heater comes out pretty easy & everything else isn't to bad. Besides if I only loosen the metal up to the side window & hold it away a bit as I repair the wood with epoxy & new materials. This may not be so bad after all, I would also reinforce this whole area as much as possible!.
Maybe for now I would just keep the old gal, as I don't have a whole lot of time to use anyway the way things are going! When one thinks about things logically $35k-40k is a lot bucks just to get a slide & more headroom! Other than this she's in good shape & everything still works (except the AC) but don't use it anyway. If I ever headed South & would install one of those Coleman AC'S Anyway thanks for the suggestions! I guess I'm going to repair it!
Besides after reading the "pros & cons" about slides, for just the two of us we probably don't need the extra room right now. I'm just going to have to install a step to help get up into the bed!
44,052 PostsLatest Activity: Oct 29, 2025
