westend
May 18, 2018Explorer
Diagnose any water around a register with the cover off. If a large tempearture differential exists between the A/C compressor and the register (think uninsulated ducts and hot roof) water may condense in the ducts or on the outside of ducts.
You can peel back the roof, if careful and the adhesive Gods are smiling.:) Start on a side, towards an end, and peel. Solvents or heat sometimes help.
If you choose to remove the ceiling panel, Starcraft may have a direct replacement available.
BTW, a pressurized interior leak test will turn up even the smallest pinhole leaks.
44,066 PostsLatest Activity: Mar 14, 2015
