ajriding
Sep 07, 2020Explorer II
Dealers? NO. Dealers can barely fix regular RV issues.
Any auto body shop can repair fiberglass. Corvettes are particularily fiberglass, so that is a start...
This is just the flat siding panel of fiberglass, not a molded fiberglass like a boat?
Either way, you can make the repair. Fiberglass is really easy to work with. Sand it down, sand it deep enough so your new fiberglass resin will be able to have thickness and still be flush with the surface. Apply the fiberglass soaked resin according to directions. Let dry, sand smooth, paint.
How good you want it to look will be a big factor in if you want to do it or have a pro do it for very large sums of money. This will be an odd fix so a body shop might charge more and take longer to get to...
44,066 PostsLatest Activity: May 12, 2026
