WoodGlue wrote:
Yes, there is a gasket seal (butyl)
Here is a video on how to do it:
How To Reseal - Reset A RV Window
Common problem.
WoodGlue
Nice educatioal vid however two things did occur that might sound like nitpicking.
1. The butyl tape seam was placed at the rear of the window, I know the butyl will or should squish together, However personally I would place the butt seam at the bottom center with a slight overlap.
2. The use of silicone to caulk around the window. Silicone at best, IMO, is a temrorary bandage.
Otherwise a very good clip.
