RoadXYZ's avatar
RoadXYZ
Explorer II
May 30, 2014
Replace Manual Awning with Power Awning ... Anyone ?
We have a 2004 Alpenlite 28 footer - thinking of replacing manual awning with a power awning .. yes, we have the breaker, etc.
Know the cost will be a mite spendy, but wanting to know if anyone else has considered or had this done ?
This is our home and thereby was thinking of doing this rather than replacing the awning material on the old manual awning. Reason - at our age it would be so nice to just push a button instead of both of us having to get out there and work the manual awning.
  • pappcam wrote:
    the bear II wrote:
    In reading through the posts on several RV Forums I decided not to go with a powered awning. It seems the manual awnings provide more flexibility options in bad weather. Tie the manual awnings down while deployed even in brisk winds. Can't do it with the powered awnings.
    My choice was based on what I had read over the past year.
    I have a power awning and I wouldn't in a million years go back to a manual awning. I have no idea what causes people to like a manual over a power one. It's one of a few head scratching opinions around here.
    Some people who dry camp like to save battery by having a manual awning, I personally wouldn't trade my power awning for the world.
  • I looked into doing as you describe but ran into a problem. The power awning mounts very different than the old one. The new arms are secured at their top edge by two large lag bolts that must go into some solid wood - not just luan paneling. The location for these is just under the gutter. Unless your RV has some blocking for this or wood framing in that location, there's nothing to secure these bolts to.
    In our case we have a thin aluminum channel up there that the side wall slips into. We had nothing solid to mount to. The existing blocking was directly behind the gutter, not under it as the power awning required.
    I suspect some shops just screw into the thin paneling and use lots of caulk to secure the awning arms to the side of the trailer but the instructions plainly spell out what the structural requirements are.
  • On our previous fifth wheel, we did install the power awning and removed the manual. It was too hard and high for me to reach. We simply brought the awning in if winds were strong. Today's automatic awnings have options for tilting and such. I would look into it. Ours was bought on ebay and we had an RV tech from a local shop install it. I think the arms were about 500 dollars, used our same roller and fabric. It worked well for us and I am happy to have an electric one on the 2010 we now have. You are right, pushing a button is so much easier.
  • In reading through the posts on several RV Forums I decided not to go with a powered awning. It seems the manual awnings provide more flexibility options in bad weather. Tie the manual awnings down while deployed even in brisk winds. Can't do it with the powered awnings.
