drittal
Apr 08, 2016Explorer
BillyW wrote:
I wonder if this is only an issue with the HD trucks. I would have shied away from the Rams had I heard about this before purchasing, but mine works perfectly. I literally can't tell the trailer is back there as far as the brakes are concerned.
All 2015+ Ram.
Problems don't start to arise until you get into heavier trailers with large brakes that require more power to fully engage the brakes.
A typical TT with 5k axles most likely will get full, or near full, brake effect. It will just take a higher gain setting than an aftermarket controller or a 2014 and earlier Ram.
My TH has 6k axles. I cannot set the gain per the instructions in the Ram manual with my 2015, but can with my father's 2012.
