lawrosa
Feb 14, 2018Explorer
Atlee wrote:
As did I recently. Now I'm happy, and I believe the battery is also.
When I first cut on all power after the "surgical" replacement, the little charge wizard was flashing about every 2-3 seconds. According to PD, this indicated it was charging the last about 10% of battery voltage.
Now, when I go out and look, it's the little light flashes about every 8-9 seconds which means it's not in the maintenance mode. This should be good.
We'll see long term if it's worth the "price of admission".lawrosa wrote:
I replaced my wfco with the PD unit with charge wizard...
Actually it stays in bulk 14.4 for 4 hours.. Period..either by itself or when you hit the button. Then goes to 13.6 for some 30 hours. then float 13.2.. eq stage 14.4 15 min every 21 hours...
44,066 PostsLatest Activity: Mar 14, 2015
