SoundGuy
Feb 15, 2018Explorer
4aSong wrote:
I like the recommendations on adding the IOTA in addition to the WFCO thereby giving a backup should it be needed and one other advantage mentioned when you sell the RV you can remove the IOTA and switch back to the WFCO.
You could also take BurbMan's recommendation but unless you also upgrade the wire gauge from the converter to the battery you won't achieve the same results as he did. Frankly, I doubt many who would be willing to upgrade the converter section would also go so far as to upgrade the wiring, in which case this would only be a half solution. Simply turning the WFCO off and installing a charger / converter close the the battery sidesteps this issue entirely.
44,066 PostsLatest Activity: Mar 14, 2015
