time2roll
Feb 16, 2018Nomad
BurbMan wrote:I think the OP would see a huge improvement just dropping in the IOTA to replace the WFCO in the existing position. Yes some voltage drop in the wires. However 14.2 to 14.6 even a distance away will be far better than 13.6 volts.
The IOTA is also a good unit and should work fine. Sound Guy is correct, you either need to mount the unit close to the batteries OR increase the wire size to the batteries, otherwise you won't realize any benefits over the WFCO unit.
Pulling new wire is not always practical in an RV.
44,066 PostsLatest Activity: May 18, 2026
