Cocky_Camper
Jun 20, 2013Explorer II
Chuck_S wrote:
Replacing the entire power center will take a while (the "converter" is just a box inside the power center).
Be sure to order all the breakers you need. The fuses are automobile types and you'll need an assortment ranging from 7 to 30 amps (in my Roo, anyway).
Needless to say both the shorepower and battery need to be disconnected for safety before starting the project.
I split my internal wall outlets to two breakers rather than all on one. A hair dryer and space heater can now run at the same time if on different circuits. System is still limited to 30 amps total, though.
-- Chuck
I ordered the entire power center. Can I not use the breakers and fuses already in the current power box? That was my plan. So you just added an additional breaker to split the outlets?
44,068 PostsLatest Activity: Jun 17, 2026
