Paul_D_'s avatar
Paul_D_
Replacement ceiling Panels
Looking for sources and or ideas for ceiling panels in a TT. I would like to go with the vinyl over luan, or ideally make my own but am having little luck locating wide vinyl rolls . Assuming wider material is used. Would be open to other suggestions as well as it is really just 2 sheets in the fwd bunk room that need to be replaced so it does not have to match the rest. Do most larger rv places carry them?
  • Just replaced the roof and this winter I will be tackling the damaged sections of the interior. No worries on the process just material location. I see sheets offered online for $20- 30 each and am assuming the shipping on 2 or 3 sheets would be out of this world. Are the panels made from 50" plus vinyl material as mine apper to have no seams. I can get 24" rolls at the home center and cover luan that way but it seems like a lot of extra work. I will definitely use plywood sealer on the back of the sheets.
    Thanks for the suggestions above.
  • I rebuilt a water damaged roof in my '73 Vanguard from the inside up and out with vinyl faced luan ply, larger rafters, a one piece aluminum roof. if you are handy you can do it.
