rightyouareken
Apr 25, 2013Explorer
Can you provide a picture of the hitch setup? One option may be to raise the L brackets up a hole or two if they are set too low. At least on the 4 way equalizer with the trunion bars, the manual calls for the bars to be parallel with the trailer frame. My bars are only barely below the trailer frame, so don't see them being a clearance issue. If you were having clearance issues at the hitch head where the round bars drop down and turn I could see other hitch options providing more clearance, but most every wd hitch I've seen has the bars even lower below the trailer frame than my 4 pt Equalizer.
44,056 PostsLatest Activity: Nov 19, 2013
