bodaciousExplorerJan 12, 2016Replacing bat-wing roll-up tv antennaHas any one out there replaced their bat-wing tv antenna wit the newer flat style that you put in the window? What kind do you use and how does it work for you?
Johno02ExplorerJan 12, 2016We use one of the flat panels at our house, range is about 30 miles MAX. But works good for that range.
Related ContentBat Wing Antenna & Drivingbat wing upgrade?Need to replace the bat wing antennaBat Wing TV - no receptionHow to tell bat wing type
