TundraTower's avatar
TundraTower
replacing brakes on 1 of 4 wheels?
Relatively new 5,400 # Dexter axles and drums on our TT, have less than 2,000 miles.
I developed had a grease leak on one wheel and that brake locked up so much it ruined a tire in 350 miles. I took it apart and replaced the grease seal, and cleaned shoes and drum with red-label brake cleaner, then laquer thinner, then more brake cleaner. Just took it for a test drive today and that one wheel is still grabbing.
SO, looks like I need to replace the shoes on that one wheel. I've never replaced brake shoes on just one side of an axle, but given how new the axles are I can't see why not. The other side of this axle is doing fine.
I know the braking on that axle will be uneven for awhile until the new shoes on one side conform to the radius of the drum, but I was thinking about using a belt sander to try to shape the new shoes to hasten that wear-in.
Anyone ever tried just replacing brakes on one side of an axle? Any reason not to?
Am I missing anything else to stop the grabbing/sliding on this side?
Thanks
