WayneAt63044
Sep 08, 2019Explorer II
I'm a bit confused but does grease on a brake make it grab or slip?
I recently experienced a grabbing brake (tire squeal) and found a brake wire broken which eliminated the others from working. Could you have a wiring problem?
True story: I had a brake spring break applying some braking leaving Capital Reef in Utah. It made the trip up to the lookout on southbound route 12 a bear and heated things up & melted off the lug nut covers. I removed the destroyed brake and lubed the bearings and drove to Mesa, AZ with only 3 brakes. I could not tell a difference while braking when compared to all 4 working. This tells me you may have more of an electrical issue than greased brakes ruining a tire.
