saintsfanfl's avatar
saintsfanfl
Replacing dump valves
My grey water valve is leaking on a trailer I recently bought but the large valve is also not in great shape. All the screws are rusted. It was basically the same price getting the whole TR38 as it was to replace the two valves. The problem is the connectors were permanently sealed. I used a heat gun and it will not budge whatsoever. I could cut the 4 inch back but the gray line has elbows all the way up underneath. I am thinking about grinding it off instead of just cutting it so that I retain the same placement.
Any advice or ideas?
  • Either unbolt and rebuild the valves or cut the ABS pipe. You will not get the glued fitting off of the pipe without causing damage.
