kaydeejay
May 21, 2013Explorer
PapPappy wrote:Conversely, the double male plug cord WILL be hot at the trailer end when it is plugged into the pedestal outlet.
The problem I have with the set up you show in the picture, is that it will have a "Hot" plug inside that cover. If you were to reach in, you'd get electrocuted.:(
It would make more sense to have an outlet type connection, and just make your shore cable a double male (one at each end). It would be much safer.
Keep in mind, YOU may know it's "live", but some child could go exploring, and get killed. At least try and make it "code".
Good luck
Commonly known as a "dead man's cord" and is certainly against NEC code if not actually illegal.
The only way the outlet pictured could be hot would be if the unit had a generator/inverter without a transfer switch.
44,056 PostsLatest Activity: May 04, 2014
