Majja13
May 22, 2013Explorer
PapPappy wrote:
The problem I have with the set up you show in the picture, is that it will have a "Hot" plug inside that cover. If you were to reach in, you'd get electrocuted.:(
It would make more sense to have an outlet type connection, and just make your shore cable a double male (one at each end). It would be much safer.
Keep in mind, YOU may know it's "live", but some child could go exploring, and get killed. At least try and make it "code".
Good luck
The trailer does not give off any AC. Especially since I do not have an inverter. So there is no way to shock anyone.
44,056 PostsLatest Activity: May 04, 2014
