mikakuja
Feb 03, 2017Explorer
I have done this, only the other way around, it's a pain... plumbing will have to be changed as the tank configuration is different. The diameter of the hole that the unit mounts in is also different and will require you build an adapter plate and possibly some re framing.
IMO, not worth the effort. The anode rod is inexpensive and easily obtained and replaced when it finally gets eaten away.
